Ok here is another one of these topics in that the more you read to more you get confused. Living here in Florida we get some serious lightning, my panels will be about 150 ft from the inverter. I believe its not advisable to add another ground rod at the panels due to creating a ground loop, so with that do I need to run an additional wire to my main grounding rod.
