Hello Everyone,
and thanks for your help in advance. Hope I'm not too redundant on the beginners forum with my questions.
I'm setting up a 12KW Growatt Split Phase Off-Grid Inverter SPF 12000T DVM MPV - Link for Specs is Below:
I would like to install fifteen 460Watt 50V Panels in a series-parallel configuration if this is the most optimal configuration. Currently my home uses between (34kWh-44kWh) per day based on my electric bill. The system will have a backup battery bank of six 48V EG4 LifePower4 Lithium batteries at (100 AH and 5.12 kWh each). I average about 8.2 Peak hours of sunlight in my area each day.
Currently in my home I have a main breaker panel that supports the electrical loads for lights, appliances,TV's, computers, refridgerator, two mini split 18000 BTU A/C units, etc.. inside the main home. I believe the main breaker box is an 100 amp box, and I also have a sub-panel I believe that's 40 amps to power other loads in the home, such as a home water pump, washer/dryer, water filter, and water softener system. I would like to operate totally off-grid if possible. I also plan to have other electrical loads, lights, 120V outlets, and a vent fan in my new Solar shed.
I addition I want to add a breaker between the 30KW battery bank and the Growatt inverter. Hope this is not overkill since each 48V EG4 battery has a separate breaker.
Questions:
1). What would be the optimal PV array configuration for my Solar Panels with my Growatt inverter, based on the spec sheet?
2). What type of PV Combiner box do you recommend for my Solar Panel setup and why?
3) Does the PV Combiner box come with fuses and breakers for each array string or are the fuses separate for each?
4). Does the PV Combiner Box ground the PV arrays?
5). What type of breaker box do I need to connect to the Growatt inverter, and how do I determine the amperage size.
Again my home is Split phase 120V/240 for North America.
6). Is there anything that I need to be aware of with the new breaker panel that will be installed in the Solar shed since I already have a main panel and sub-panel in the home?
7) Since the home is obviously already grounded, do I need another ground for the new breaker box that will be installed next to the Growatt inverter?
8) Should the battery bank be grounded? How?
Again, thanks for your help and responses in advance,
Respectfully,
Cabo35
Growatt 12kW Split Phase Off-Grid Inverter | SPF 12000T DVM MPV
Signature Solar provides solar components and full kits for off-grid, grid-tie and custom diy solar systems. Providing Solar 101 and hands on experience within the solar industry. Quality inverters, bifacial solar panels, complete solar kits, solar batteries. Holding best in class brands such as...
signaturesolar.com
Questions:
Respectfully,
Cabo35
