charlie22824
- Jul 19, 2022
- 41
I Think I have this correct but not so sure. I have 2 200 watt Renogy solar panels that I will be running in Parallel. I need to run about 20-22 foot of extension cable from the front of the sprinter van to the rear. I was going to use 6 or 8 AWG wire for this or would I need 4 AWG. I think the max amps would be around 24.
I was also wondering can I cut the MC4 adapters off the end of the Windy Nation Solar Extension cable and wire directly into the Charge controller instead of buying more adapters. thanks so much for the help ?
solar panel specs
Max Power 200w
Open Circuit Voltage 27v
short circuit 9.66a
optimum operating voltage 22.6v
optimum operating current 8.85a
max system voltage 600vdc
solar panel specs
Max Power 200w
short circuit 9.66a
