Used solar panels for sale (installed in April and June 2021)
Qty 3 - Longi mono Solar Panels 310W - $150.00 each
Qty 3 - SIL-330 NL (Grade B - tested) 330W - $130.00 each
Grade B panel have the same output as grade A panel. The cells may be not aligned, tapping wire across the cell, dirt on the glass,.... Some of them look perfect. All the solar panels were tested and working well. There is no spec sticker at the back of the panel and no warranty for grade B solar panel.
These were purchased from Solar Shopping Mall in Mississauga.
They have be removed as house is being sold
Model LR6-60HPH-310M Series Hi-MO3 Manufacturer Longi
Model | LR6-60HPH-310M |
Series | Hi-MO3 |
Manufacturer | Longi |
Mechanical
Type mono Dimensions 66" x 39.2" x 1.38" Weight 41.5 lbs Frame Black Anodized Aluminum Alloy Frame Connector MC4
Type | mono |
Dimensions | 66" x 39.2" x 1.38" |
Weight | 41.5 lbs |
Frame | Black Anodized Aluminum Alloy Frame |
Connector | MC4 |
Electrical
Watts (STC) 310 W Max Power Voltage (VMPP) 33.3 V Max Power Current (IMPP) 9.30 A Open Circuit Voltage (VOC) 40.30 V Short Circuit Current (ISC) 9.86 A Max System Voltage DC 1500 V
Watts (STC) | 310 W |
Max Power Voltage (VMPP) | 33.3 V |
Max Power Current (IMPP) | 9.30 A |
Open Circuit Voltage (VOC) | 40.30 V |
Short Circuit Current (ISC) | 9.86 A |
Max System Voltage | DC 1500 V |
Model SIL-330 NL Series Manufacturer Silfab
Model | SIL-330 NL |
Series | |
Manufacturer | Silfab |
Mechanical
Type Mono Perc Dimensions 67" x 39.4" x 1.5" Weight 42.3 lbs Frame Anodized Aluminum Alloy Frame Black Connector MC4
Type | Mono Perc |
Dimensions | 67" x 39.4" x 1.5" |
Weight | 42.3 lbs |
Frame | Anodized Aluminum Alloy Frame Black |
Connector | MC4 |
Electrical
Watts (STC) 330 W Max Power Voltage (VMPP) 33.3 V Max Power Current (IMPP) 9.92 A Open Circuit Voltage (VOC) 40.5 V Short Circuit Current (ISC) 10.42 A Max System Voltage DC 1000 V
Watts (STC) | 330 W |
Max Power Current (IMPP) | 9.92 A |
Open Circuit Voltage (VOC) | 40.5 V |
Short Circuit Current (ISC) | 10.42 A |
Max System Voltage | DC 1000 V |
