Dr._Prof_ECECS
I have an Eco-worthy 24V AIO inverter system with 2S-2P batteries and 2S-2P solar panels (4 panels in all; bought used, buy one get one deal! Each panel rated 30.8V Op. voltage and 8A ==> 240W or a total of 960W generating like 720 to 800Watts. I had it in ground mount in a rental house for a year and moved them to another rental home. After the move the unit worked well for a week, but suddenly the output has halved. I traced the issue to one pair of solar panels (I used the individual fuse for the two parallel connections to operate one at a time). For 10 minutes (my app records every 5 minutes) I had like 1) 54.6V, 5.6A 2) 53.7V, 6.0A, then it went 1) 24V, 0 A. 2) 0, 0, 3) 0,0, 4) 24V, 0A, and drifted slowly to 22V, 0A in an hour.
I connected the other parallel 2 solar panel alone and they were the ones giving me the half power at approximately 40V, 8 A. or 320W.
Can anyone figure out what is happening to those 2 panels where the open circuit voltage is only 20V and getting zero current. I thought of testing each panel (OC Voltage) but I am a 75 old senior citizen and thought I will ask first if there is anyway to check further without physically yanking the MC4 (or whatever) connectors as it is a PITA in the Tucson hot sun. I have the knowledge (see my screen name) to test further if given any hardware suggestion like opening the electronic box under the panel to test voltage etc.
Thanks.
Here is a snapshot when both were working. Peak like 720W with both working at 45V, 8A, I suppose.
Thanks.
