Any suggestions for a 'safety tether'?
I've put in 8x m8 stainless steel couplers/coupling nuts into the roof gutter of my van.
I was originally going to install crossbars and mount my solar panel in the traditional way, however - due to the curvature of the roof, the solar panel will be quite high due to cross beams, brackets, and the panel itself.
I've instead thought of using ABS plastic solar mounts and installing the solar panel that way. The solar panel im using is a common size so should be able to easily replace new (or find a second hand replacement). It's also a common solar panel.
Anyway. I'm thinking of using a sikaflex or similar to bond the brackets to the roof of the van, and utilising some of the coupling nuts (maybe 4?) as a safety tether.
What would be the best way for this?
I was thinking one at each corner of the panel. I'd appreciate some help in terms of what material (I imagine it'd have to have a significant capacity to absorb a sudden force of the jerk of the solar panel if it were to come off). And if it should be attached to the underside, side or top of the solar panel frame.
Thanks
