I am new to this forum and haven't figured out how to thank somebody for their response. My first question was about battery connections to an inverter. THank you Michael for your generous response and time.
This one is in regards to solar panel connection.
I bought two 400 watt, 24 volt panels which I will run in parallel. I have two 8 year old panels, 180 watts each 12 volt. Is it ok to connect those in series and then connect them in parallel with the two new ones, as to getting 1060 watts 24 volt together?
If that works, I would need a fuse going to the charge controller, which is 50 Amps, as the panels together produce 44Amps. Is that correct? The charge controller is 80Amps, or is the fuse 80 Amps?
Is that an inline fuse or a breaker, close to the panels or close to the charge controller?
Thanks in advance to the person who might be able to respond to this question.
The size of the cable needs to be 6 or 4 from panels to charge controller?
