So I have 2 x 100W TopSolar brand panels on the roof of my campervan, wired in parallel, connected to a Renogy Voyager charger, and 100Ah battery + inverter.
this all worked great until a week ago, and I notice I have no charging voltage. I separated the panels, and found one was working fine, but the other appeared to be shorted - pretty much zero ohms in either direction.
The junction box is potted, but I've managed to remove the panel connections - there are just two conductor ribbons on the panel. With the box removed, the panel is generating 20+ volts, same as the other. But the box itself appears shorted - I'm guessing there is a single bypass diode potted in the box which has gone bad.
So I'm wondering, can I maybe carve open the box to reveal the dud diode, and replace it?
Also, given there is only a single diode (I assume) is it doing anything with the panels wired in parallel? It wont work as a bypass presumably?
Unfortunately, assuming I can fix the panel, I don't think I can wire in series, as that would give 40V and the controller has a max input voltage of 20V.
Replacing the panels would be a real pain, as they are bonded to the roof. So repairing is partly to save ££, but also to save labour (and more eco-friendly than dumping existing ones!)
I'd be really grateful for any input.
