In your case the other variable is the micro inverters.
Yes, I’m going to sort out with my Microinverter supplier first that the Microinverters are performing correctly.
This post / thread was anticipating that even after that issue has been addressed, there’s a reasonably-high probability I may have some or all of my 6-year-old 12 335W panels that have degraded more than they should have…
A simple short circuit or resistance load with switches like Hedges suggested would be the quickest way to get a high level ranking of panel performance.
Short circuit allows you to measure Isc, but typical degradation results in a ‘slumping / rounding’ of the I-V elbow around Vmp and Imp, and a short won’t help to characterize that.
I think I can rig up something using my two spare electric water heater elements.
Then test each micro with your best performing panel to test each micro. How practical that is may depend on your roof?
I’m not going to waste any time checking my MicroInverters unless instructed to do so by the supplier. They seem responsive so if they are treating this issue as a warranty claim, I’m going to proceed as they instruct.
The Microinverters are reporting much more power production than I’ measuring (as in close to 200%), so either the Microinverters are faulty and the panels are fine, or the Microinverters are fine except for reporting / gateway monitor but the panels have degraded.
If the supplier replaces all the Microinverters I will do that first - testing anything on the roof will not be easy - step one is to get to the point that reported array production matches what I measure getting into the mains panel (which ties to what Tyler utility meter reports).
The least expensive and easiest way without going on the roof would be a simple Watthour meter on your Solar leads on the wire(s) from your roof and compare that daily production to what your micro controller is reporting during the same solar day. I bought a simple Coulomb Counter on Amazon for less than $40. I think it was DC but a quick search would also reveal ones that work on 240 Volt AC.
Thanks for the suggestion but for now, the Microinverter supplier seems to be accepting the discrepancy between my annual clamp-meter current measurements at the end of the home run and the production report coming from their gateway monitor.
Power generated should equal 240V x measured current, and at the moment, reported power generation is almost 200% x 240V x measured current…
Once they get me to the point that reported power generation ties to measured power generating, I’ll finally be able to get an easy bead on how my 6-year old panels are performing.
If it turns out they’ve degraded severely after only 6 years, I’ll need to characterize how many and how badly before determining whether any defective panels remain safe enough to be put back into the array.
I’m happy I did a DIY install with components I selected myself, but managing failures and warranty issues like this is the hidden cost of that decision…
