You need to see what the max is for voltage and amperage. You can't calculate it. My MPP solar for instance has 145v max, 80a max, but it certainly cannot accept 145vx80a=11600w. I am running 94v most of the time at a max of 24a. I usually don't see much more than 1600w out of my array especially because my loads are very low.
My guess is the amp rating on the AC300 is at least 40a, so you can just use 250 panels (cheap used) and run them 3S3P. That will give you about 95v at 24a and provide 2250w max (probably more like 1800w max). You can get 250w panels from Santan for $50 each (plus $200 shipping or so if you are in the USA). That's like $600 or so out the door for the panels.
Or you could use higher wattage panels as well. You are not limited to 8a for sure. That would be insane. Maybe call them to get the actual specs.
