Hi and thanks for taking time to read this! Not sure how much specifics are needed, but I have 12 100 watt panels paired up in parallel, and then six pairs linked together in series. These go into a 100 amp circuit breaker, and then into a 60 amp charge controller. That charges up three 100ah 12 volt Lifepo4 batteries wired in parallel.
This setup has been working without issue for almost two years. Two days ago, it stopped charging the system. After some troubleshooting, I realized that if I check voltage between the input of the circuit breaker, and the solar panel input of the charge controller, I get an appropriate voltage. As in like 118 volts depending on the sun. If I check the voltage at the circuit breaker output, and the solar panel input of the charge controller, I get only 12 volts. I've replaced both the circuit breaker leading into the charge controller, and the charge controller itself. Same issue as it only registers 12 volts after the circuit breaker going into the charge controller.
Any ideas would be greatly appreciated!
