No idea why your are having a problem understanding the difference between rated panel output and actual output but you will eventually figure it it out, I hope. Other than that, apparently you have not read any of my responses above to the Op so since you refuse to read them, I will list them.
The amount of solar panels, watts or volts will be limited by which solar controller you will be using.
Your controller should be rated in max amps and max volts. That will tell you how many watts of panels that you can attach to it.
Try to match your panels as you buy them either in voltage or amperage. Mixing panels that are not alike usually will not be very efficient.
Since info is kind of sketchy, let me tell you what I have and what it does from there. I have 4- 305 watt panels with a 40 amp solar controller. The controller is rated at 40 amps and a max of 150 volts. Anything over 1050 watts, per controller specs, will not be used or is wasted. Even though I should be getting 1220 watts at best sunlight and coolest part of the year, I have only been in the range of 600 to 900 watts at best times. I say this to let you know age of panels, shading, angle of the sun, etc, will all effect watt production and you will probably never see the same wattage that you add up from your panel array vs actual production. I average 4 to 5 KW per day of used /stored DC current. Some solar controllers like mine can be over paneled. I am running a 24 volt setup. With my controller it is rated at 150 volts and a max production wattage of 1050 but it can be over paneled up to 3000 watts. When you over panel, you will collect more energy in inefficient times of the day but the in the best times of the day it will only produce 1050 max charging wattage.
Without knowing the specs on your controller we will not be able to know how many panels can actually be attached so you will need to find that info.
Ok, based on your controllers specs you will not be able to accomplish what you listed earlier of 1000+ solar panel watts. With that controller you are limited to 12 or possibly 24 volt panels. You are also limited as to how you can add extra panels because you are limited to 30 to 50 amps depending on the controller that you actually have. So as an example this is what you can possibly do if you purchased more of the exact same panels. The
max on the 30 amp model would be 5- 100 watt panels and if it is the 50 amp, you could put 8-100 watt panels. All wired parallel not in series.
You know, not once did I tell you that you were wrong but you did tell me that I was wrong. " Disagree if you like but you would be wrong. " Don't know if that is just immaturity or your need to be right. This is a form that shares thoughts, ideas and practical real world experiences. Just because your knowledge or experiences do not line up with someone else, it does not mean that they are wrong. I stand with what i have shared because I have personal first hand knowledge of it. So regardless of how many times you say that I am wrong, I will just grin and take it as lack of experience. Good luck in the future.
btemplet, if you would like to discuss this further, PM me.
