Solar Panels for Sailboat?
tholley
Vancouver BC
Hi,
I’m planning on adding 3 450 watt bifacial solar panels to a stern arch on my 47’ sailboat. Looking for high performance and suitable for marine environment with max width of 41”. Would like to use “tier 1” panels. Any suggestions for panels that fit this bill would be much appreciated.
thank you,
Tim
Photovoltaic panel manufacturing is a mature industry. There’s probably “dozens” of decent brands.
Any recognizable brand making bifacial panels is going to be ‘good.’
REC, Hyundai, Canadian, Jinko, Kyocera, Longi, Silfab, Qcell are just some that are off the top of my head. There’s probably 20 USA-made mfgrs.
Could be good idea to look and see if you could make more power by having a second panel under the top one. I believe the backside of a bifacial does not produce the same power? Or test a bifacial. flip it over and see how the power is different. Microinverter might be good for shadowning of the mast?
Hi,
thank you,
Tim
Recommend you post this in the Marine forum, where all they talk about is marine rated panels...
Are you sure that a bifacial panel is the best solution? Will there be enough of a reflective surface behind the panel to justify it?
If they are mounted up in the rear like I see most they should have a lot of extra power with the sun reflecting off the water or even a white boat.
