Welcome aboard
@Crooner88 -- we use the AC200 as well. Your new 300 specs indicate:
INPUT
AC Charging Cable Input: 3,000W Max.
Solar Input: 2,400W Max., VOC 12-150VDC, 12A
Car Input: 12/24V from Cigarette Lighter Port
Maximum Input:
5,400W, with AC and Solar Input Simultaneously
At first glance at the 300MAX you see the "solar" input is limited to 150 volts DC AND 12 amps of current. In other words, you have three limiting factors, total watts input limit, at 5,400 watts, voltage limited to 150 volts on the PV input and current limited to 12 amps on the PV input. You can read about this in the 300 users guide:
link to download T -- The good stuff starts on page 19.
What really controls all this are the specs on the panels, Voltage and Current. A typical 200watt 12-volt panel might produce 18-volts at load and 12 amps of current. If you have the panels in series you see the voltage increase, if you have panels in parallel you see the amperage increase.
You might be able to do all this with the two inputs on the 300MAX. The B300 also has charging input, not as much as the 300MAX. Again, you will be limited by current and voltage.
Example, on the 300MAX with
150v divided by 18v = 8.3 8 panels @ 18v = 144 volts -- This would probably be too close to the limit
7 panels might be the max --
Thoughts?
Good luck!!
