I was using 4 460 Watt 40V panels to run a pool pump. It was running fine on sunny days, but not on cloudy days.
So I added 4 more of the same panels, but now learned from the installer that this would overpower the mppt pump controller which is max. 100V / 15 Amps.
I was assuming that the pump controller would only pull the amps needed, but according to the installer, the panels would push all amps generated to the controller and damage it on a sunny day.
Is there any way to make this work with the 8 panels? Is there a device like a limiter so it would use all energy generated on a cloudy day, but only let pass the 15 Amps max. on a bright sunny day to not destroy the pump controller?
I now have 8 460 Watt panels and according to the installer can only use 4. He couldn't provide any solution other than buying a new pump controller that would allow for higher amperage.
Any other solution to make use of all 8 panels?
