Hans Kroeger
- Dec 30, 2020
- 128
Bug or feature? The JK-BMS can be set into its sleep mode by pushing a button for 5 Seconds. In sleep mode it's power consumption is close to zero. It also goes automatically into sleep mode, if a cell voltage drops below the "Power Off Voltage", which I set to 2.6 Volts.
By chance I learned that the application of an external "charge" voltage which is somewhat higher (some 1.8 V) than the actual battery voltage, the BMS wakes up and enters its normal mode.
Personally I consider this to be a bug. If I turn Off the BMS intentionally (pushing a button) I don't want the BMS to switch on automatically if my Solar System delivers a charge voltage. With no load being present, it will finally charge the Battery until SOC = 100%.
This is exactly what I try to avoid at long rest periods, because of the accelerated aging of the cells by the high SOC.
From my perspective, it is OK if the BMS wakes up from its standby mode, after a "Power Off" event.
However, after it was turned off by pushing the Off button. it should stay in its sleep mode until the button is pushed again.
Comments are welcome.
Cheers Hans
Cheers Hans
