AZRoadrunner
- Mar 18, 2021
- 83
The AV cart I found through Amazon is absolutely perfect for building this solar power generator. All of the pieces slide together and it's easy to remove a panel, add plywood and install parts, and then slide it back together. Here's the current state of the build. When the construction is finished, one shelf covers the lower cabinet, then another shelf is on top. The inverter will be on top.
