I am interested in using the battery backup DC with a solar panel but Chamberlain just told me "You would eventually damage the transformer and logic board in the motors" if you run the opener only on the batteryI realize that there are posts that address this question, but let's just say that as far as experience and understanding goes, I look up to newbies because their knowledge and experience greatly exceeds mine....That said...
I am aware of DC, battery-backed-up openers that have their own lighting - maybe 1/4 to 1-1/4 hp - whose battery is supposedly able to cycle 50 times without a charging source. What I fail to find info about is what size panel it required to run (when sunny) and charge (when not) such a simple setup. And is it that simple? Should I have an extra battery? I'm in southeast Michigan, do I need this extra battery in a ventilated, insulated box? Why?
Is it really just simply attaching a 100watt panel to the southern face of the front of my garage, running the line inside, getting the opener installed, and hardwiring it?
I look at plans and websites and see 'inverter," followed by, "cheap is bad," or "only have a professional electrician install an inverter."
I just know that I ain't paying $4500 to get power to my garage.
Thank you in advance! Safe Travels.
Model 8550wlb
