re-read the question...![]()
True. So for those who are not feeding the grid the “meets” portion of the “meets or exceeds” would apply. Yes?I should mention that unless you are feeding the grid you only produce what you can consume.
Average | Jan | Feb | Mar | Apr | May | Jun | Jul | Aug | Sep | Oct | Nov | Dec |
High | 31°F | 37°F | 47°F | 56°F | 66°F | 77°F | 85°F | 82°F | 73°F | 59°F | 44°F | 33°F |
Temp. | 24°F | 27°F | 37°F | 45°F | 53°F | 64°F | 71°F | 69°F | 59°F | 47°F | 34°F | 25°F |
Low | 18°F | 21°F | 29°F | 36°F | 43°F | 51°F | 58°F | 57°F | 48°F | 38°F | 28°F | 20°F |
97.6% of consumption.A quick survey.
How many months of the year does your Solar Production meet or exceed your Consumption?
Batteries count. Generators don’t count.
I may be able to do 12 months this year but only if I replace the propane furnace (which we don't use) with a pellet stove. Then I can give up the electric heat via oil filled radiators in the winter.9 YTD, hoping that changes to 10 at the end of Feb and 12 in a year.
I put in a Harman pellet stove 3 years ago and have been happy with it. Pellets this year were around $330 a ton delivered and I expect to use between 2 and 3 tons for the whole heating season. I'm planning to replace the mini split heat pump I have now with a high seer unit this summer so I'll get more use out of that as a heat source.I may be able to do 12 months this year but only if I replace the propane furnace (which we don't use) with a pellet stove. Then I can give up the electric heat via oil filled radiators in the winter.
You bring up something I meant suggest earlier.Pellets this year were around $330 a ton delivered and I expect to use between 2 and 3 tons for the whole heating season
Central PA area. Temps could be anywhere from 10F-60F9 YTD, hoping that changes to 10 at the end of Feb and 12 in a year.
That’s in the same day!Central PA area. Temps could be anywhere from 10F-60F.
