SomedayBlue
- Aug 21, 2020
- 7
Hi solar power folks,
I'm in the process of adding solar power to my sailboat. In my quest for info, I found Will's youtube channel, which has been a useful source of information.
My set-up: almost 2 years ago I bought a sailboat with a 48v Electric Yacht motor. The motor will re-charge its battery bank at a fairly low rate: on the order of 100w when the boat is sailing ~6 knots. My boat also came with a 2kw Honda generator in a deck box, but no solar. In addition to the 48v 12,000wh motor bank, there is a 200ah 12v house bank. Both banks use 6v AGM batteries and are mostly getting recharged at the dock.
There are several issues with the Honda generator, but the biggest is one I realized after I got CO detectors for the boat: it produces a lot of CO. For this reason, IMO, it is unsafe to run while at anchor. It's also very noisy and uses gas. I want to cross oceans and sail to remote places, so a big part of the attraction of solar is that it cuts down on the consumables I will need.
My current project is adding the solar power components to the existing system so I can recharge away from the dock without running the generator. I've bought all the components I think I will need for the electrical connections and hope to install them all soon. I've attached two diagrams, one with just the existing components and one with the stuff I plan to add.
