Rooftop-Special
Newb here with another question.
Thanks in advance for the patience. You guys are more seasoned and this might be an elementary question.
I got lucky and stumbled across the fact you have to pre-charge the capacitors in an inverter via resistor. More specifically large inverters. This made me think what else am I missing, it's a "I don't know what I don't know" type thing
I've read Will's book, read the forums, etc but the inverter pre-charge thing I accidentally stumbled across. And I'm glad I did?
When I have the system done I plan to have you guys give it a once over, so there's that.
Are there any other things I need to do prior to startup? I know the obvious things like check connections, wiring, etc...
My system will probably be:
12v
(4) 450w panels (Alexus)
(4) 100/30 mppt controllers (victron)
(3) 200ah batteries (litime)
(1) lynx distributor (victron)
12/3000/120-50 2x120 (victron)
Victron shunt
8 awg PV cable/connectors.
4/0 wire for batteries and inverter
System will be for my RV.
Thanks again,
Casey
12v
Victron shunt
Thanks again,
Casey
