i had an idea to use solenoid valves a temperature sensor and a microcontroller to cycle between different plumbing configurations for a solar thermal system
i.e from cold start have the 4 panels running in series, once a set temperature is reached (70-80 degC ?) the solenoid valves will switch to series-paralel then when the set temperature is reached again switch to all 4 panels running in parallel and the same in reverse with a lower set point as the temperature cools off
series - 1,2,3,7,8,9 closed 4,5,6 open
series parallel - 1,3,5,7,9 closed 2,4,6,8 open
parallel - 4,5,6 closed 1,2,3,7,8,9 open
does anyone know if this has been done before and if it will be worth while?
