StinkerBean
- Aug 9, 2022
- 10
Back in 2002 my dad had a well installed at our ranch. We had no power close by so had to run it on a generator whenever we had a chance to drive out there which wasn't as often as we would have liked. At the same time we had a pond dug out, around a 50x50 size. We were never able to keep water in there 100% of the time due to not going out there as often as we needed. A couple of years ago the pump finally went out.
We are looking at getting it back going but I want to do a simple solar powered set up so that it runs more often and will possibly keep water in the pond throughout the year. This will be on solar only, no batteries so will only run when the sun is out. I was originally looking at RPS but on one of my hunting forums I came across a member on there who has put together his own solar well pump kits for less than $800. Does not include the panels though.
I found the well report that was done back in 2002.
-Water static level 100ft
-Depth to pump 180ft
-Depth of well 300ft
Here is what his kit includes:
2 7/8" diameter 304 stainless steel well pump (requires 3" or larger cased well)
mppt pump controller
stainless steel hose barb adapter
pump rebuild kit with spare drive screw and poly bushings
2 float switches for low well pump safety, and tank full pump shutoff.
pump features brushless motor, permanent magnets and NSK bearings.
3/4" cast stainless steel outlet.
max lift 310 feet! with max output of approximately 8.5 gpm.
requires a minimum of 300 watts, 24-48 volts of solar panels to operate.
So based on you're experience do you guys think this kit will work well enough to keep water in the pond? He states that at around 150ft it should put me around 4-5gpm's. I'd more than likely run three 250W panels. This well will only be used for the pond, will probably add a spigot of some sort to use for washing hands and general stuff. Trying to keep this as a budget set up. Any advice would be much appreciated.
