Hello everyone. I'm planning (nothing bought yet except some wire, tools, LiFePO4 cells and ordered BMS from overkill) to install 10x200w panels on my 42' 5th wheel RV. After measuring, that is what I can fit tops. My rig is a 50amp, so I plan to buy two 3000w Victron MultiPlus 24v inverter/chargers to be able to feed the two 120v feeds (split phase) in my rig. To keep this part short, mostly going all Victron for a lot of it.
My main concern is connecting these panels. How do people wire them up? They are sold with 10ga wire and I see people parallel and Series linking these in pictures and it looks like the wire that came on the panels. If each 12v 200w panel is putting out about 5.2 amps, linking 10 would be 52 amps. Now if you parallel one side and parallel the other, then series the sides together to get 24v you would still be at 25 or so amps right? A 10ga wire is rated for 30amps. Wouldn't these start to heat up around noon at the most sun exposure?
I guess what I am getting at, is I am trying to figure out how to safely wire 10 panels together, to get the 24v I want and the wires to be safe and not burn up my trailer.
A little reassurance from you guys would be great. How would you wire them? Would you tear open the doide om the panel and solder on 8ga? If I did do 8ga, my solar prep on my roof will have to be redone as well, as it is 10ga and that doesn't look fun to rewire (who knows how they ran that through the walls). Thanks for any help and insight.
Oh and please correct me if I'm wrong. I have an IT background and this is my first DIY solar project, so my knowledge is basically just researching this stuff, no hands on. I want to do it right, especially with buying about 10 grand worth of stuff soon. I definitely don't want to break anything.
