Hey all!
New to the forum so i hope someone can help me out! I have been working on designing an system for our house and have settled on either the Enphase IQ with Micro-inverters or the SolarEdge 11kw single phase inverter with optimizers.
The Enphase design is pretty easy and I have no issues with that. My issue is coming in with the SolarEdge. Here is what I am planning.
2 Pole mount systems each with 12 Trina TallAX 400W panels. According to the specs I can string 12 of those together so basically each pole would be it's own string. I am planning to either use the P405 or the P505 Optimizers on each panel. According to SolarEdge I can have a minimum of 6 Optimizers or a max of 25 per string but not to exceed 6000W per string. The TallMAX panel has a PTC output of 375w per panel so each string would be 4,500W. My plan is to run about 40' from each pole to an combiner that will be mounted on the house giving me the option to add some roof panels in the future as our power needs increase. From the combiner I need to run about 100' to where the inverter will be located by our incoming power. My question is how do I size the wire for that DC run? My head says I need to add up the voltage on the string which is 12 panels * 41.1v or 493v since the string will be combined in parallel the voltage will stay the same but of course the wattage will increase. According to the inverter specs it's max input voltage is 480v but according to the optimizer sheets I am well below the wattage allowed.. So my first question is what spec do I follow? Total wattage or total input voltage? Unless I am missing something this seems to be conflicting. Tieing into that question how do I size my DC wiring from the combiner to the inverter? I assume I need to take the combined wattage of 9kw divided by the 493v to get 18.2amps for the install size of the system. Does that seem right?
Am i missing anything or just thinking about this too hard?
Thanks for any help that you can provide!
