tomy2
escape artist
OK, I bought ten Solarever 370W ( SE-166 83-370m-120N ) half cell mono Perc panels two months ago. We installed six on the roof in series, feeding a EG43kw 48V off grid inverter and two EG4 Lifepower4 lithium batteries 48V 100AH.370 solarever panel
These six panels never outputted more than 1.5kw to the inverter. So yesterday I tested two of the four unused ones, in full sun, facing the same direction as the roof, and tilted at about the same angle (18 degrees). We put the positive lead from the multimeter to the panel positive and the negative lead to the negative panel connection. zeroed the meter and tested for dc amps. They only read 5 amps, when they should read 10. We also tested the dc volts and they read 39.4 , what they should be.
