My system had been running for 15 months with no issues up until last Saturday. 9.7 kw array, currently 61 kWh of EG4 LL batteries, grid tied and 11 kW propane generator. After the first winter I decided to add 4 more batteries getting me to the 61 kWh of capacity.
Last Saturday afternoon, power in the house went off. I went down to the garage to check out the inverter. The red alarm lamp was on and the inverter was beeping. F13 (Grid Mode Change) was annunciated. After a couple minutes the alarm light went out and power came back on in the house. I thought all was good - for now.
Sunday I just happened to check the app, batteries were at 100%, but no power was being sent to the grid. Bright sunny day. Went down to the inverter and pulled up the grid config page. Things were screwed up. 50 hz block was checked along with the single phase 220v block and the grid mode entry was blank. I tried to set things back to what they should have been, but the inverter would not accept any of my changes. I power cycled the inverter a couple times with no success. Tried calling SolArk, but was put on hold and eventually rolled over to voicemail, so I left a message (they responded to the message I left about 24 hours later). An hour later I called again and got a tech. After logging in and looking at things, she said that she would have to push new s/w and do a factory reset. S/W had been updated less than a year before. She then did some set up on the unit and got me back in the ball park to where the inverter appeared to be doing what it was supposed to do.
We discussed what could have happened to cause the issue. I may not be understanding what she had told me. But it was something about some system issue that SolArk had where something had gotten pushed out to some of the SA15s in service. She said that they had gotten a bunch of calls earlier ( a week ago?) and she was surprised that my inverter exhibited the problem much later. I don't know, but that is what I think she was telling me.
I did a follow up call on Monday to further discuss the issue. The tech I spoke with was not knowledgable and was no help. So that is why I'm posting to get some advice from the experts on this forum.
Question 1: What actually happened? If they can randomly push something through the dongle that screws up my inverter, maybe time to disconnect it and use Solar Assistant to monitor performance.
Question 2: Why was I unable to make changes on the Grid Setup page?
Question 3: On the main display, the load icon (light bulb) is occasionally highlighted in yellow. I can't find anything that tells me what that means. Went down several times today to get a picture, but it refused to cooperate. Any idea what the yellow means?
Question 4: On the page that comes up when one taps on the Battery icon. There is one field highlighted in red (see attached image). Manual says the CT is wired backwards. This problem did not exist prior to the "EVENT". Is this a s/w issue or something broken in the inverter electronics?
Last winter, when I had multiple days of low solar production, I had some TOU tweaks. Of course those all got wiped with the factory reset. I do not like the TOU description in the manual and I have not been able to find anything really useful on the web. Can anyone point me to a good tutorial?
Thanks,
Lowell
Thanks,
Lowell
