Outpost_51
I see there is a mention of a fix for a problem with flickering lights on another brand of inverter.
I'm curious to know if anyone is aware of a similar fix for the Solark.
I have a Solark 5K, ( without an auto-transformer)
The firmware has NOT been updated since purchase in late 2021 ( there's no internet connection - off grid)
I see a slight flicker in all of my LED light bulbs typically when a motor is running in the house.... ie, mini-split, ceiling fan.
(the mini-split is "inverter technology")
I have tried different brands of light bulbs, LED and incandescent. ( and it's not a solution)
Does anyone have the same issue?
Is the auto-transformer a solution for this?
Has anyone seen this problem "fix itself" with a firmware update?
could this be a bonding or grounding issue?
(neutral is bonded in the inverter, this is a single 8ft copper ground)
Thanks in advance,
Mike
Thanks in advance,
Mike
