benlloydking
- Mar 6, 2022
- 3
Hello,
I have a SolaX X1 G4 3.7kW Hybrid inverter and 5.1kWp of Solar cells. I am saving up for a triple power battery but in the mean time I have access to a large number of free 12v Yuasa REC36 AGM batteries from a school project I run (Greenpower Racing). They will have done 20-30 cycles.
The X1 inverter manual states that the battery voltage should be between 80 and 480v peak and that "X1-Hybrid G4 series inverter charge and discharge system can be equipped with high voltage lithium battery and lead acid battery." I have enough batteries available to build a 9s3p configuration which would be a nominal 108v and 11.6kWh capacity. I understand that the actual capacity will be lower, perhaps half this amount, but still enough to be useful. I also understand that AGM batteries do not normally require a BMS as they will self equalise. The x1 hybrid manual states how to set min and max SOC, but not how to set the type of battery or the nominal battery voltage.
How would the inverter know what 100% SOC is? Should I be able to set what voltage 100% SOC corresponds to or is it just that it infers this from the batteries limiting current as they reach peak capacity? How do I prevent the inverter from trying to charge at an excessive voltage? Would a BMS be needed for this system? If so which BMS would work?
Inverter manual: https://www.solaxpower.com/wp-content/uploads/2021/02/X1-Hybrid-G4-User-Manual-614.00495.00.pdf
Any thoughts and responses are gratefully recieved.
Thanks,
Ben
Thanks,
Ben
