When faced with lack of support you need to start being a bit creative. So assuming a Gen 2 inverter of one model should be similar to another Gen 2 model from the same maker you can sometimes get info from other manuals.
Note in the settings you tell the Inverter what is connected as the Meter with the options (page 73)
Mode Select
For Mode Select, the user can choose from Disable, Meter, CT. The default setting is
Disable. When Disable is chosen, the function will be shut off.
When the user wants to enable this function, choose Meter or CT according to the actual
application, the meter or CT is used to monitor energy exported to the grid.
Also look at page 74 for checks on function.
First check that these options are in the settings menu.
Mode Select
