Hi all,
I’ve just added a Solis 6kW Low Voltage AC Coupled Inverter to an existing solar setup that’s on the UK Feed-in Tariff (FiT), so I’m trying to avoid anything that could mess with the tariff.
The inverter is showing what the solar is generating, but the excess power doesn’t seem to be going into the batteries. I suspect the issue might be with the CT clamps — maybe wiring or orientation?
If anyone’s got a similar setup, I’d really appreciate any advice or tips. Photos of your wiring would be a huge help, too.
Thanking you all in advance
