Seen the discussion thread on different modes, but not quite clear on the outcome.....
My use case:
* cheap rate electricity 00:00 - 05:00
* standard tariff in day
* off-peak - if batteries <100% charge batteries from grid; house gets power from batteries then grid (typically lowish usage overnight)
* peak - house gets power from solar then batteries then grid; excess solar charges batteries any left exported to grid
* grid outage - house gets power from solar then batteries
So essentially I run from batteries in the day charged by cheap rate grid overnight, with solar powering house to reduce demand on batteries, and topping them up if possible.
I saw a solution that used home assistant to achieve this - is there a setup on the inverter that will achieve the same?
thanks!
My use case:
thanks!
