Hi everyone,
So there are already some threads on this forum about this matter, but having followed all of them several times, I still don't have a solution.
I have a Solis-RAI-3K-48ES-5G AC Coupled inverter that was purchased without the energy meter or the RJ45 cable. I purchased the ACREL ACR10R 80A unit separately from the ACREL store on Aliexpress.
Following threads on this post, I have made my own cable using a spare ethernet cable, using 2 wires from the cable (the green cable and the green/white cable) in positions 3 and 6 of the RJ45 connector.
The meter is connected to the mains and the attached CT connector is positioned around the live cable, and the meter correctly displays the energy usage of the house. The meter has 4 LEDs, the top "RUN" LED is constantly green, the 2nd "COM" LED is off, and the 2 bottom LEDs flash red.
The inverter does not seem to detect the meter when the 2 pin connector in the METER port is attached, and when looking at the inverter settings, it lists the "Meter Voltage" as NULL.
I have made an additional cable, I have tried inserting the 2 RJ45 wires into the opposite pin of the METER port, I have checked that the inverter is setup to expect a "1ph meter".
I have attempted to go into the ACR10R menu system, but it is very confusing, and has menu headings of SYS, In, Bus, IO and UER
I would be so grateful for any help from someone with some knowledge about this issue
with thanks
with thanks
