@Umski how did you get on with your pylon?
I got the config in this morning. I can see that the battery comms are still working with BMS data still received by the inverter so that's all good (but it's comforting knowing that the BMS should protect me from stupid settings too...).Worth a try with the user-defined option imho.
not the best time of year to get it going, especially today! Can you not charge up at cheap rate overnight?... seems a bit of waste of precious energy doing diddly squat once it's reached the cut-off SoC!
No sadly not, no E7 or smart meter which is fine by me for the moment - there was a brief glimpse of sun just after 3pm which got it up by 1% from 19 to 20% - I've been trying to calibrate a SoC for my open energy monitoring - I would have preferred to use the BMS value but deriving it seems to be marginally less complex with what I have at the moment!not the best time of year to get it going, especially today! Can you not charge up at cheap rate overnight?
All useful stuff - I always feel I'm taking from the internet and rarely contributing so this thread has been a whole heap of use and hopefully to others tooI got the config in this morning. I can see that the battery comms are still working with BMS data still received by the inverter so that's all good (but it's comforting knowing that the BMS should protect me from stupid settings too...).
I had 30% from my SOC overnight, so I set user-def to 25% and could see that my 40A discharge limit was working, curiously it stopped discharging at 22% rather than 25%. I'll see what happens with the SOC trickle down now - I've disable the time of use to see.
While poking about the solid app I found that the battery BMS reports an operating current of 0.5A (25w). So, perhaps it is mostly the BMS using that trickle of power and not the inverter (or a bit of both).
how?...calibrate a SoC for my open energy monitoring
After some discussion on the open energy forums, I was asking how folks were getting their SoC values from batteries (easily) and without a Modbus interface and associated h/w it doesn't really make it easy with my existing h/w so the suggestion was to use the battery charge/discharge power value to add into a kWh accumulator and then do some more calcs to calibrate an SoC within the CMS - it will be a progressive tweaking and is really just a rough gauge to show on my display (there is an app that combines the house/solar/battery values plus SoC which I didn't have)how?
Yes that's the one - are you making use of an SoC value and if so where is the value pulled or derived from?OK, thanks - that makes sense. We use the SolarBattery app from the emonPi which gives a great overview - guess that is the one you are referring to.
Me neither. Obviously the BMS will protect the cells from extremes which is what seemed to happen. What doesn't make sense is why did the inverter not stop using battery power when the overdischarge value was reached (I think you said that was 22%) and why did the inverter not force a charge once the force charge % value was hit (i guess you set that to 10% or 15%)?... I don't really understand how it happened.
I like your style ???? What did you change the force charge setting to?After a short panic my crazy side brewed up a nutty idea... what if I could wire some old DC chargers serially to provide ~53v... some time later after some soldering of 2x20v and 1x12v old laptop chargers and random power brick outputs together I had a reliable 52v @1amp or so. It was enough to power up the inverter via the DC, change the settings to force charge, give the battery 1% of juice and reset the UVP error! I knew there was a reason I kept all those old power bricks! This was their moment! [please don't judge me for Frankenstein electronics]
Sensible move.For now I have reverted to the PYLON setting until I understand why that happened.
Ouch will bear this in mind (still only had one sunny day yesterday that got me up to 80% SoC so just over 24 hours without the grid! But bugger all sun today to recharge!) in case I move to user def settings...good recovery hack mindSo I had a bit of a disaster with the user-def settings. Somehow the battery hit 0% over a couple of hours. It was doing its normal thing, holding steady at 25% then with slow decline. I checked on it a couple of hours later, and it was offline. I don't really understand how it happened. There is no data in that period at all, such as discharge rate, to explain why it happened. All my discharge limits, force charge, low volt setting seemed reasonable and were confirmed with the manual.
Of course, it is a bit of a catch 22 - the inverter is powered by the battery, so needs battery power in order to charge the battery from the mains!
Do you mean the case of a metal battery? With my inverter the -ve battery connection is just connected to the inverter and not grounded.... Unrelated, how are folks grounding their battery banks - straight to the main incoming ground in the meter box or looping through via the inverter casing and then through the PE conductor via the CU?
Yes the Pylon comes with a 10mm ground cable that 'earths' the casing - since it's a sizeable cable, just from a practical perspective if folks are just looping through or taking it straight out to the meter much like a bonding?Do you mean the case of a metal battery?
me neither, but my case is wooden.My case doesn't have a separate ground either...
Wish I could get that much broadband speed out of my batteries too@Umski 80% charge gave you 24Gb hrs? I'd need a 30kw battery to do that!!
That was a weird typo/auto correct!!me neither, but my case is wooden.
