Hi, I was hoping that someone could confirm that my interpretation of the Solis datasheets / manuals are correct. I currently have a RHI-5K-48ES-5G 5KW inverter with just over 18 Kwh of Pylontech batteries. I was looking to change it out for the 6Kw version however it appears that the limit on battery discharge is still 100 amps? I assume this means the only time I would ever be able to use the full capacity of 6KW is in the day with both the batteries and solar (if producing enough)?
