Worded
Hi all,
I'm running a Solis RAI-3K-48ES-5G inverter with two Pylontech US5000 batteries - a setup that has been running without issue since installation in February 2023.
It's connected to SolisCloud using a Solis wifi dongle and I had Inverter Control enabled soon after installation, which gives access to update most of the inverter's settings.
We are on the variable Octopus Agile tariff here in the UK so I regularly use the Charge / Discharge option (on SolisCloud under the Inverter Control -> Self-consumption menu) to set timed charging periods when electricity is cheap, free or negatively priced, or to prevent the inverter from accidentally discharging the batteries when we plug the car in to charge.
When I logged in to the app yesterday the Charge / Discharge option was no longer available.
Has anyone else with Inverter Control access on SolisCloud had encountered this? I've raised a ticket with Solis support, but it would be useful to know if it's just me encountering this or if remote Charge / Discharge functionality has been removed for everyone.
Of course in the meantime I can still set timed charging or discharging via the inverter screen, but doing it via the app is so much more convenient (not to mention ten times faster).
Many thanks in advance!
