I am relatively new to everything solar. Our house is currently off-grid. I've been searching for a few weeks now for resolutions to some of the issues I'm having, but it's hard to come by specific answers to specific questions so I figured I would give in and start a thread.
Here is my setup, so far:
48 x 100w Renogy panels.
1 EG4 Flexboss21 + 1 EG4 Gridboss
6 48v 100ah Eco-worthy rack batteries in an Eco-worthy rack.
Cummins Connect 20000 generator - Model RS20AE
Everything was installed by me except the propane -> generator connections.
The solar stuff was easy enough and works fairly well. I've got my eye on some TOPCon panels once I find someone to build a permanent home for them. Until that happens, I'm relying on the generator far too much (it rains daily for whatever reason) and that's where the issues arise.
For starters, the Cummins generator wants a Cummins ATS. I did not realize this when I purchased it or I would have gone another route. The Cummins also needs AC power to keep the battery charged and the system ready. I will worry about that later though. What I need is a way to use the dry contacts from the Gridboss to start and stop the generator. Current work around is to walk out to the unit and start it manually using the local controls.
A few minutes after the generator starts, it will take over the loads from the battery/solar. About 10 minutes after taking over the loads, it will start charging the batteries. I have no idea why it takes this long. Occasionally, and randomly, the generator suddenly stops supplying any power to the system. Battery charging stops, and the loads go back to the solar/batteries. The generator is still running, at idle. After a short period it will seem to "recover" and again take over the loads, and then a while later start charging the batteries. Sometimes, without dropping the charge/loads, it will charge the batteries to the "Charge End SOC(%)" setting that I've chosen at which point it stops charging and continues to handle the loads.
I have no idea if any of that behavior would change if I had the remote stop/start functioning properly. I have my doubts. I've changed settings, such as "Batt Charge Current Limit(Adc)", so the generator was only working at half it's rated power. That doesn't help. I've had it working close to it's rating with some extra loads (dryer), and it continued to charge the batteries until the SOC cut off.
I've gotten the event "W015: GEN voltage and frequency abnormality" a few times, however it does not coincide with the generator dropping the charging/loads. In fact just before I started writing this post, the generator was running and dropped the charging/loads and I have no alerts from today at all.
When the generator takes over the loads, everything is smooth, however when it starts (or stops) charging the batteries the power to the house "flickers". It's very strange though. I have a Bluetti UPS (AC200L) on my PC, which has worked flawlessly during grid outages (back when we were on the grid), however during one of these power fluctuations, my computer monitor and PC will restart anyway. Ceiling lights, without a UPS of course, seem unaffected. I've toggled "Seamless EPS switching" on and off to no avail.
I was running the shipped firmware for most of this time. However I finally gave in and toggled the "* Remote tech support" to accepted and updated the firmware for the Flexboss. I had already updated the Gridboss with the phone app. I did not use the phone app for the Flexboss because it was not listed in the drop down menu, although as I understand it, the 18KPV firmware is also for the Flexboss21. Updating did not change any of this behavior.
So I guess I'll ask a few questions now.
Is there a semi-easy way to control the Cummins RS20AE with the Gridboss? I am not opposed to wiring up a relay, but I would need detailed instructions. Buying a device to place between the two and simplify my life would be fantastic.
Why is the house power flickering when the Generator starts/stops charging the batteries? I purchased the Gridboss specifically because it seemed to be well suited to function with a generator. I'd actually prefer the generator only charge batteries, instead of taking over the loads. I don't believe that is an option in the settings available to me.
Unrelated to the generator. It seems to me that the cable provided with the Eco-worthy batteries are undersized for an entire rack. I've got 4/0 from the master battery to my busbar, yet the remaining 5 batteries are supposed to be charged through the 2 awg(?) they provide? Doesn't make any sense to me. I've already purchased 2/0 to replace the 2 awg between the batteries. A busbar in the rack would make the most sense. I've also considered connecting not only the master battery (top rack space) to my busbar, but the last slave battery (bottom rack space) as well with the previously mentioned 4/0. Is there any reason not to do such a thing? The last slave battery has two open terminals there for the taking.
I plan to rebuild this entire system in the near future with different hardware. The EG4 stuff was quick and easy, but I don't know that I'm ready to rely on it for the coming winter months. The instructions are lacking, the monitoring software is buggy and weird, and I just don't know if any of it is living up to my expectations.
The Eco-worthy batteries however, have been fantastic (besides what I consider undersized cables but maybe I'm doing it wrong)!
Sorry for the long post, I just don't know how to describe it with less words. I'm happy to answer any questions about settings or whatever.
