I've searched the threads, but can't find a discussion about my specific situation.
I have an MPP Solar LV6048 and 4 x EG4-LL batteries (400ah/20.48kwh) . I am not charging with solar yet. Only charging with utility power currently.
I have the AC input of the inverter hooked up to a dedicated 30amp circuit in the main panel. L1, L2, N, & G on inverter connected with 10 gauge wire (12 gauge ground) to the main panel.
I have setting number 11 on the inverter, Maximum utility charging current set to the default of 30A. When charging, my Victron smart shut shows I'm pulling just over 27amp and roughly 1450 watts. When I check the power draw on my dryer, which is also on a dedicated 30 amp circuit, it pulls around 4000 watts.
Can anyone shed some light on why the inverter is only pulling a fraction of the watts that a 30 amp circuit is capable of delivering?
It takes around 14 hours to recharge the batteries when they are discharged to an SOC of between 5%. I figured I could charge faster than that with a 30 amp dedicated circuit.
Any assistance is greatly appreciated.
Thanks in advance.
Thanks in advance.
