Good job!Finished charging, it took an indicated 153.68Ah on the Riden. A few minutes after, the pack measured @ 14.09V. I've buttoned it up and finished messing with this unit. It is now my best unit out of all 4 I have! All it took was a week of messing around with it
Looks like spending an entire hot Texas summer in my garage stored at 100% SoC didn't affect it much.
You are well on your way to grasping the understanding of this!
Some final thoughts:
Most of these batteries that are of reputable makers will generally have a >100% initial capacity vs rated.
It's most likely that your packs initially were never able to charge to 100% at cell level so there's not a baseline for comparison.
Total Wh should be = or > than Ah, and if not it would indicate there is an issue in your: battery, wiring or connections.
The nominal 12.8V (3.2V/cell) is a good value to use for calcs.
