FilterGuy
Solar Engineering Consultant - EG4 and Consumers
The cable itself was actually very hot. You are correct, typically its the connection. Very common issue.
My lugs were nearly the same temperature as the conductor, from what I could feel.
But whether it was the connection or the conductor, the cables were well made and over sized, and there were still current sharing issues. I do not know how to calculate the interconnection losses between the lugs, but this is a factor as well. I would assume that with the crimper I used, the terminations were gas tight cold welds. But again, more factors going against you.
This is why bus bar w/ equal length conductors connecting the server racks is the best method.
I have used the diagonal configuration for ages in past packs, and I always had these issues.
Keep in mind that wires can get quite hot even if they are sized correctly.
