Some ways to run a fridge on solar energy
When looking up fridges, I have noticed several comments that say the R600 refrigerators are not to be used in garages. Lawyers are over sensitive to some car driving into them.
The manufacturers are concerned about the temperatures and dirt issues. Garages tend not to have HVAC and leantoward extreme cold during the winter and heat during the summer. I'm in GA and keep my garage door closed except to enter/exit. I've never had a problem.
DC fridges are stupid expensive and very rare compared to standard AC household units. For the price difference it would seem that taking the hit in efficiency using an inverter for a regular fridge is worth it. If you're a prepper type, it also makes sense to use readily available equipment in case the SHTF. DC refrigerators are just flashy toys for people with money to burn.
I'm proposing taking an old fridge or free fridge off craigslist and swapping in this:
If dc fridges are $2000.00 or whatever, why not get the size fridge you like and pop this puppy in there?
Cooling capacity-wise, do DC compressors draw less juice than their ac counterparts and if so, how much? Also, let's ignore inverter draw and just examine the fridges themselves when answering this question.
So, the maximum that compressor can handle is a bit over 5 cubic feet. It costs more than half what a 21 cubic foot refrigerator costs. The real fridge runs on 50 watts or so. If you don’t want an inverter, I suppose that may be a reasonable choice, but for most people, it doesn’t seem to make sense. My cheap Reliable inverter is rated at 30 watts idle. I am not sure what it pulls when working. But, it sure seems more reasonable to have a real fridge.
Ok. What size compressor is needed? Just engaging in fat-chewing here.
My 3k, 6k surge inverter runs 12 watts idle. My fridge shows 120 watt draw via its power measuring smart switch but a 78 watt draw with power factor correction.
Would I save about 50 watts if the compressor ran on straight dc?
I just looked at the spec on the compressor. I didn’t quickly find the current draw, but the size was scaled for ‘small’. Nothing wrong with that, but the cost/benefit doesn’t add up IMO.
Here is the spec sheet for that compressor. It appears that it pulls from 50 to over 100 watts. For 5 cubic feet.
Saya it does 647 Btuh, that translates to about 14 cubic feet.
Where are you coming up with 5 cubic feet?
The calcs I ran say 837 btuh for 16 cubic feet. This compressor does ~640.
That is what the maker says. Danfoss apparently makes good stuff and the $$$ they get for it show. It is specialty equipment and as such demands a premium.
My fridge in the camper pulls something like 600 watts running on 110 volts. It is an absorption unit and they have (had?) their place, but that seems past for most applications. Specialty units…
Oh I see. It says 18-150 liters. I didn't see that.
Weird. Using another calculator it says 850 btuh is all that's needed for a 16cuf box. *sigh*
I finally remembered to check the watt meter on the fridge. It has averaged 456 watts per day for the last 17 days. Not sure that can be beat. A 21 cubic foot fridge/freezer running on less power than a 20 watt lightbulb. Knock wood this thing lasts.
For an alternative approach: I unplugged my fridge over a year ago so have been living without one. It took some effort to adjust, learning to ferment and shopping differently, mainly for fresh produce instead of packaged. Also realizing that much of the world and everyone before about a century ago lived without.
A century ago people filled their ice houses in the winter and year round they used that ice to feed their kitchen ice boxes.
Call me lazy but I find electric refrigeration to be so much simpler.
Just curious, do you use electricity?
Yes but but from late 1800's on, they had daily deliveries of milk, eggs etc along with a horse-pulled cart that carried ice they bought and put in their ice box (refrigerator).
I see your point but canning and shopping become full time jobs.
Was a very early adopter of DC compressor referigeration, I have two Grape Solar branded refrigerators that I bought from Home Depot. I bought the first for $800. with a 1 year warranty. It failed at 11 1/2 months and was replaced under warranty. The failure was the breaking of the freezer compartment door, minor but they had no parts so sent me a replacement fridge for free. It was simple to fabricate a Styrofoam “plug” door with the approiate sized holes to achieve balance between referigerator and freezer temp.
These units draw 42 watts at 10-15 volts or 20-30 volts DC or 115 volts AC with the built in power supply.
On average they have a 20% run time over the day 4-5 hours in Coastal California
In a test I sucessfully ran one on a 50 a.h. 12 volt battery and 1 only 50 watt solar panel with a PWM controller, It did just fine but had a hard time with a rare 100 deg F. day
Minimum recommended is 100 a.h. battery and 100 watt solar
The Grape Solar units are now nearly 20 years old and still doing fine, Ive added a third unit which I salvaged from a wrecked late model Volvo Tractor made in Sweden
These run from a 426 amp hour 24 volt bank of Rolls Surette S-530’ L-16 batteries now pushing 20 y.o.
Grape Solar has exited the business but I do see very simular units marketed in other countries for reasonable prices
$900 for a 17 cu. ft. unit in the Phillippines . In America we have a huge power grid so we do not need to have really efficient devices. In third world countries It’s a different story altogether
If anybody still does ammonia referigeration I have the original Dometic dealers diagnostic and repair manual.
This has theory of operation and is a gold mine of rarely available information on adsorption refrigeration .
It’s in Adobe PDF format, PM me and I will email a copy
I was with you before starting. Before doing it, I expected I'd have to spend more effort, time, and money on food, and that things would go bad. I was pleasantly surprised to find the change led to fresher food and the effort was more like taking care of a pet or practicing a craft. I got out what I put in, so value the effort.
The longer I do it, the more what used to feel like effort feels rewarding. My biggest sacrifice is screen time, which has turned out to be a benefit.
Yes, though I'm in the middle of an experiment disconnecting my apartment in Manhattan from the electric grid. My goal was one month, though, frankly, I didn't know how I'd make it past a couple days. That was May and now I'm in my sixth month. Here's a podcast episode I did on it. I allow myself a cheat: I can plug in my computer and phone at NYU, where I teach, but otherwise I disconnected the circuit connecting my apartment to the grid. I still get hot water from the building.
We've had several rainy days in a row, so haven't gotten to charge my battery, so haven't been able to cook for a few days. Fall vegetables make great salads, though.
It's led me to cut back my screen time, which has ended up improving my life.
I've also learned more about traditional cultures, including the Hadza and San, which go back long before the 1800s -- fifty and two hundred thousand years. I haven't canned, but I ferment enough that it's become simple and quick. I live near a farmers market and belong to a CSA, so getting food regularly isn't hard. I also volunteer to help bring farmers markets to underserved communities to replace McDonalds, Starbucks, and delis that extract value and time from them. I'm in this for systemic change.
Urban and even suburban folks can get by without even owning kitchens. Just walk to the local store, market or eatery. Many can do without owning much household appliances like clothes washers since there is a laundromat or cleaners just down the block. Heavily urban folks don't need cars to get about they just ride Transit and have big things delivered by the stores. Heck even your night time lights can be supplied by all the street lights shining everywhere. Pretty easy to cut down on electric use if someone else supplies things.
If you live in the hive all your needs can be taken care of.
