dougbert
I fully agreeInstead of 20 or 30 kWh more battery, how much more PV would be needed to accomplish the same goal?
Just overpaneling - you have enough SCC already.
(What we really need is a way to turn surplus electricity into fuel we can store in a tank.)
I have the following limitations and possibilities at my place:
- small lot, .09 acres - almost all space I could use have panels on them, save one
- currently my system will support 4 strings of panels.
- Schneider controllers can each support 3200 watts @ 48v, so it is possible for 12,000 watts
- currently at 7300 now as mentioned. Still have 2 idle 355watt panels needing modification and installation. That would bring capacity to 8,000 watts
- Last place for filling the last array string is over a Pegola over deck, both not yet built. Not ready for it. Then 3,200 watts of panels on the pegola is my plan
- During the winter I will have the money, space and time to add more batteries
- looking at 10 bi-facial panels 400watts each, can only use 8, but the order is 10 at a time (SignatureSolar)
4th array needs:
- Engineering Plans and permits for deck and pegola: $1500 (got a bid)
- Deck and pegola parts: Unknown at this point (wag: $2,000+)
- 10 panels $2300 (including shipping)
- Time to build
thanks
