Frank in Thailand
making mistakes so you don't have to...
Hello Thaiger,A friendly hello to everyone. I am DE and live in TH. A SOROTEC REVO II 5.5 KW inverter with 200AH LiFePO4 battery also works here. I am very satisfied with the device.
My question: Which monitor software do you use and how do you connect? "DessMonitor" or the "SmartESS" app works but my account always starts again at 0KWh when I reach 65KWh, I can't find a server administrator who can change the setting. The "SolarPower" software looks good, but is there anything better for Sorotec?
(Better watch out for name issues 555)
(5 is pronounced "Ha" in Thai, so... 555 = hahaha) (Thaiger is a news channel in Thailand)
Welcome to the forum!
Sorry for the late reply, I've been out the country for a while.
Monitoring software..
Many different options, none by Sorotec!!
I have solarman what they started with, now they use different company.
Also a possibility to use laptop with cable (usb?) (Never tried)
Monitoring works when the information provided is accurate.
And sadly to inform you, it isn't.
At 3500 watt the MPPT is reasonable efficient and reports accurate enough to use.
At 4000 watt... It's bad.
4500 watt .. crap.
5500 watt ?
Not going to happen.
Even if you push 6000 it will only convert 4600-4700 but will report 5500 watt.
The 4600 loses + 500 watt...
Into heat.
From DC to AC..
At 50% it's OK, higher regions..
Not so good.
Don't get me wrong, I do like the Revo II for its price/quality.
And if you charge with 3500 solar, and use the 5.500 inverter up to 3500 watt, it's efficient and stable energy.
Use it to rated max...
Expect a lot of heat, what isn't used energy, not efficient.
Also their shunts aren't really accurate, especially on the higher numbers.
It seems like it was built with the 3500 in mind, found out it could peak at.... And sold as is the peak
(Normal strategy in China)
I was naive when I bought them.
Well...
Not for the Inverter part, that is covered many times in this and other forums.
Mppt part.
Like inverter, they should only be used normally at 70% of rated capacity.
For solar... That is max production at noon, 70% for rated mppt.
For inverter, normal peak power consumption.
Where short time burst like microwave or blender aren't an issue.
Several hours can/will be.
(For performance and efficiency)
There are several AM meters available that use external shunts to keep track of the power going in and out.
(For solar line, if your setup is done as it should, only power in, not out at night)
Several have reporting options and with open energy monitor you can do A LOT!
Victron have high quality AM meters (Shunts) they cost some, with great software.
If you like free software (open source) OEM is the place to be.
Shunts are just a few bucks, so are the (China) AM Meters
Personally, I use the atorch electric energy meter. For the main battery performance.
Solar...
As it's 300-350v not many options there.
Most AM meters go to 100v.
I already fried several who claim to to higher voltage...
Lol.
I now have visual monitoring
Indeed...
2315 Is seen as 2245 watt..
And this is where the inverter show reasonable efficient numbers.
1737+162= 1900 watt.
2315 watt goes inside.
1900 watt is being used.
According to the Revo and external shunt.
Good news is that the 1732 is actually higher
Using the build in shunts for morning will give you insight with consistent incorrect numbers.
Insight will be OK, using the numbers to make production and use calculations..
Your into a nice journey
Down the rabbit hole ?
