jdege
- Dec 16, 2020
- 138
I'm in the basement, working up an electric outboard, prior to installation on my boat.
Components:
The charger also included a cable with spade connectors.
The battery has screw terminals, and the spades on the cables fit these fine.
The problem is the Victron shunt. The screws on it are larger, and the spades won't fit.
So what should I do?
Components:
- Elco 9.9 electric outboard
- Epoch 48V 100Ah LiFePO4 battery
- Epoch 48V LiFePO4 charger
- Victron BMV-712 battery monitor with shunt
- Drill out the spades so they fit?
- Cut off the spades and crimp on new? Note - I don't have any crimpers that would serve.
- Have a couple of short bits of cable with spades of the right size, and connect to the existing cables? Again, note - I have none of the appropriate materials or tools, and how would I connect them to the existing cables?
