skoot
During prolong periods of sunless days, I would like to just shutdown the entire solar system. I was considering using 20a spdt switches as a means of switching individual breakers on the critical load panel to another breaker on the main panel. This way I could fire the inverter up when conditions permit and switch individual circuits over from the main to the critical with out having to manually disconnect the hot wire from the breaker on the main and reconnect it to the breaker on the critical and reverse the process when the sun disappears for a extended period. Is this a solution to my problem?
