HappyTrails
- Aug 26, 2020
- 2
Greetings!
I've been in construction nearly a decade. Primarily home remodeling, am proficient on most aspects involved... but it is with some deal of humility that I admit, solar power is kicking my butt! I bought Will's book (which is fantastic) but I still feel like there's some details I'd like some feedback on. I am humbly asking for your help.
After watching one of Will's videos, I came to realize that there would be benefits to running a 24v vs a 12v system. That's where my problems start.
Setup:
12ft box on a Express 3500 van.
Renogy 40A CC
(2) Trina 380w panels:
Giandel 3000w 24v inverter:
And 32 of these cells:
for a total of 400Ah 24v.
Everything in my build is electric. 110v fridge rated at 297kW a year. 1800w induction cooktop. Lesser draw appliances are a toaster oven and a hot water heater for a recirculating shower (obviously not all running at the same time).
Questions I have are 1) Should I wire these panels parallel or series? With there only being 2 of them but still bringing in 760w, I'm confused. The 40A Renogy CC is rated to 100v (I believe) but the open voltage of the two panels comes to 97.6v. Too close to max to run them in series? From what I've read it would be ideal to run a combination of series and parallel, say if I had 4 or more panels. However, that does not apply here. If series is optimal, do I need to add a second identical charge controller?
2nd question: how do people wire circuits off an inverter... from the outlet receptacles? Do you use an extension cord? I'm lost on this portion of the system.
Thanks in advance for any advice! I really do feel like a solar dunce, heh.
Setup:
Renogy 40A CC
Trina Solar 380W Tallmax Perc Monocrystalline Solar Panel
Ideal for large scale installations Reduce BOS cost by connecting more modules in a string 1500V UL/1500V IEC certified Maximize limited space with top-end efficiency Up to 193 W/m_ power density Low thermal coefficients for greater energy production at high operating temperatures Highly...
www.solartechdirect.com
Affordable Electric Vehicle Batteries & Components from Electric Car Parts Company
Electric Car Parts Company is your one-stop-shop for affordable electric vehicle parts and components including batteries. Shop our selection and order now!
www.electriccarpartscompany.com
