I know a ton has been written on this.
I will have a grid fed Victron Multiplus via w subpanel where the neutral ground is separate. The output from Multiplus will be going to a load center. Included a photo.
Please correct if I am wrong. It looks like I need to add a separate ground bar and use it for the ground circuits so I can keep the neutral and ground separate.
Would I also add the ground from the ac input from the Multiplus to this bar as well?
