jon.clapham
- Nov 8, 2021
- 6
Hi,
I will shortly be installing a 5kw wind turbine from Tesup. However, the Tesup charge controller is 4kw and the only inverter they supply compatible with the UK power grid is 2kw (badged Growatt). I appreciate the turbine will not go above 4kw unless we have extremely high wind and so I'm happy to accept 4kw. However, the 2kw drop for the inverter is too much for me to swallow. Can I split the dc into 2 inverters by placing them in parallel and therefore potentially receive 2x 2kw on the ac side? The output from their charge controller is 48v and I cannot find an inverter larger than 2kw with an MPPT startup of 50v or less (this would be too easy).
