I have a Sprinter van and currently considering swapping over to 48v’s and installing a second 48v alternator. I’m planning on eliminating solar completely and removing the two 50A Orion XS that I have installed in parallel. I currently have 920Ah’s installed with all the Victron goodies so it won’t be too hard to convert it. I’ll need a new inverter, swap out the batteries and install a 48v to 12v step down converter.
I would recommend having MB install the second alternator. They know what they’re doing and it has to line up perfectly or you’re going to run into trouble if not done right. I got quoted $1100 for them to do it and then I would wire the rest. As mentioned they do sell bracket kits that make the install a bit easier.
I would reconsider using that inverter and consider using a Victron inverter that are made for the marine and RV market. There is a lot of movement when going down the road with these mobile vehicles and they’re built to take that beating. Same reason why stranded wire is preferred over solid Romex in these environments.
You’re probably getting push back from these installers as it would be hard to integrate the alternator regulator with that type of inverter. Depending on what alternator you choose you will still need a regulator to communicate with the system for charging hence why they prefer you to use a Victron system. Way easier to integrate it with the Victron Cerbo for communication. WakeSpeed and Zeus are two common ones that are regularly used. There is also third one that I can’t remember the name at the moment.
Also consider going with the newer Arco alternator with their Zeus regulator as they are way better built and easier to program the Zeus regulator. However, also a bit pricier.
Attached is a good video on how to install it but it has a lot of good info on the process and they get into a lot on the subject.
Hope this helps.
