What Apexium boxes did you get?I was talking to someone at CurrentConnected yesterday. Rackmount batteries are in short supply right now. Personally, I'd go for the Ruixus, but when you add in shipping + the hazmat tax, it really does boil down to where you invest your time.
I just did a Docan order. 66 EVE 280Ah Grade A cells (2 spares), 4 Apexium boxes (this is my time vs money saver, I don't want to build an enclosure, and I want the cells enclosed). Plus I'm fairly new, so the guidance on balance leads, etc. is worthwhile.
I had direct contact info for one of their sales folks, so my order was all via email. The box itself looks like this: https://www.docanpower.com/index.php?route=product/product&path=241&product_id=532What Apexium boxes did you get?
link?
ThanksI had direct contact info for one of their sales folks, so my order was all via email. The box itself looks like this: https://www.docanpower.com/index.php?route=product/product&path=241&product_id=532
You can also get one that has standard M8 terminals (https://www.docanpower.com/index.php?route=product/product&path=241&product_id=579) if you ask. I have both. I should've gotten all the M8 versions. Nothing wrong with the connectors, but they're somewhat proprietary. I can get lugs anywhere.
If you're making your own cables and decide to order from them, ask them to add in a few sets of the connectors. I made my own cables with their connectors. I also have a custom set I made with M8's on one end and their custom ends on the other. Lets me hook a new battery up and charge with a Chargeverter before introducing it to the full pack.
Translate to english: Someone is monitoring the sei with the base application.Alguien está monitoreando el sei con la aplicación base.
Translate to English: Has anyone gotten an updated firmware for these SEI units? I think my drives are outdated and doing strange things. I want to use my batteries before connecting them to the mains, but when I get to 90%, the system goes back to the mains and recharges the batteries.¿Alguien ha conseguido un firmware actualizado para estas unidades SEI? Creo que mis unidades están desactualizadas y hacen cosas extrañas. Quiero usar mis baterías antes de conectarlas a la red eléctrica, pero cuando llego al 90 %, el sistema vuelve a la red eléctrica y recarga las baterías.
Interesting, I must have checked it at some point. Testing with inverter power showed 141A of inrush per leg and it couldn't start it.I need over 1/2 of that just to get my shop air compressor started.
I own a 15 hp 3 phase still in the old shop but that would be a challenge to get started on inverter power with other loads present in the shop.
HESP might run parallel but the ASP is different. PV with grid assist (MXLOD setting) or PV with battery only.Right. Parallel to the grid it will power anything so I believe the 2 times rated power for surge is without any grid assistance
I took a pic of the battery settings page - hereI think you mean your battery bank is 15s (15 cells) so runs at these lower voltages than a typical 16s (16 cells) pack.
Looking good! Very clean installationAnd for my own set up - Finally got the parts I needed to install the 2.5" x 2.5" risers from the main DC and AC trough up to the inverters.
As I noted back a few pages, I needed to separate the AC from the DC and figured it was easiest to do this with two separate AC and DC ducts.
Then I also figured it didn't make a lot of sense to run three side by side conduits from the inverter to the trough - easier to run the small vertical trough and use an end plate adapter.
- I spaced the AC duct off the wall 2-5/8" so the 2.5x2.5 had room to pass by easily to get to the lower DC trough.
So the upper PVC finger wire management is for the Comms, then the AC trough is below, and the DC trough below the AC. The DC rises up on the left hand side to the main disconnects - that go to the ESS1 and ESS 2 towers via 4x4 trough behind the battery banks, and on the right hand side the DC trough rises up the wall to allow easy connections with 1" EMT nipples into the PV disconnects.
Been planning for nearly a year, bought the inverters last summer, finally all up and finished on the wall.
A thing of beauty.And for my own set up - Finally got the parts I needed to install the 2.5" x 2.5" risers from the main DC and AC trough up to the inverters.
Looks that way.Can anyone confirm whether a 10kw / 12kW HESP can be used in a grid-tie configuration without batteries? I’d like to set it up for consumption/export since my utility provider currently offers netting. I plan to add batteries in the future.
Great placement of the main disconnects! On the way out, even if running, they're easy to slap down! Is your computer setup dedicated to power management? Where have you stashed the batteries?Looking good! Very clean installation![]()
no computer - just a monitor keyboard and mouse connected to the Solar Assistant on the wall - I bought a wall mount small screen swing arm, and added some brackets to hold a piece of plywood for the keyboard support.Great placement of the main disconnects! On the way out, even if running, they're easy to slap down! Is your computer setup dedicated to power management? Where have you stashed the batteries?
Nice will be hooking up two of these in parallel pretty soonAnd for my own set up - Finally got the parts I needed to install the 2.5" x 2.5" risers from the main DC and AC trough up to the inverters.
